Phil,
I came down to Central Florida for “inland” flying because Lorran and Shannon are the best…but you are correct…their playground is outstanding! It has been hard work…but such a nice place to fly! Great experience!
Question for you. Why did you go for the Mayday square vs the LT? I see both, I’m on the light side (160 LBs soaking wet with chance in my pockets), and am trying to decide.
The Mayday Square weighs 1.01kg. I am within the tested weight range, so, it is what I bought. I have an Ozone Angel Square 140 on my Tornado, but the Tornado is heavier with a tank of fuel. The Angel weighs 1.77kg. I guess to answer your question, the Mayday Square has been around a while…and is already very light.
“Parawaiting” paid off again. I got to “feed the disease!” Here is a flight that I made at our Pensacola Beach LZ on 01-08-20. The batteries weren’t full, but at least I had an opportunity to get into the air…between bad weather and on a relatively warm evening. It was a nice flight for January.
Here are a couple of recent build adjustments.
I adjusted the Cobra buckle position for the battery mounting strap.
The sand and bits of shells at the beach are pretty tough on the two lower props, so, I added 1" X 9" strips of 3M protection film to all of the props. I have been lightly sanding them with with 400 grit and applying a couple of light coats of oil based urethane, but I wanted to see if the 3M film would work better. Hopefully, the balance will be close.
Here is one of my recent flights on an overcast day at our Pensacola LZ. I like my 4X more each time I fly it!
I wanted to report back on the 3M protection film that I added to each of the props. I have flown the unit several times since the addition, and the props are still in great condition…especially the lower two…they were the ones that were getting chewed up so bad. As far as the balance goes, I can’t tell that the tape changed anything. Give it a try if you are have an abrasion problem.
I had two flights yesterday, and the props still look great. This is the material…I used 1" X 9" strips:
Thank you for the info
Seems that even the big rotors are protectet via a tape…
Since the beaches in the Panhandle are closed and my friends and I will not be flying for a while, I decided to make spare net from .7mm Dyneema. (8 knots wide X 50…I can always trim it down.) I used the Hercules Dyneema that Paul (GliderPilot) used, but I ordered .7mm from Amazon for $8.30 for 100M … just wanted a bit heavier line to work with…it is still much thinner that what we already have on the units.
This is the knot that I used…Dyneema is very slick, and this knot doesn’t slip:
This is the net making video that I used but used the above knot for extra security:
Here are a few pictures of tools, Dyneema and finished product… my 3D printer is a bit small, so, I designed 1/2 of a netting needle where I could overlap 2 halves and glue them together:
netting needle.stl (156.9 KB)
It was a fairly enjoyable process, and I now have a Very strong spare net. I hope this is helpful to someone.
I wasn’t going to post this, but I do enjoy watching flying videos of all of our OpenPPG members. Since the “lockdown” hit our area, flying is out…I work online, exercise, watch NetFlix, Youtube, read, get slapped for following too close, etc.
I swear the walls are closing in on me! …and you too probably. Anyway, here are my last two flights on March 14th. I am really missing this…like I am sure that you are too, so, if you have any flights recorded, please thinking about posting links to them. I know that I would appreciate it! Thanks in advance! Bill
Some flights at home…
https://www.instagram.com/p/B9_HvjXhWh3/?igshid=1eqbkfksl9ogo
maybe can’t post link here but check my insta @flysurfkite i hace some flights posted there
Hope you enjoy them
It finally happened…I knew that it would. The other day I aborted a take off at a new LZ and ended up taking a knee. Unfortunately, the thin carbon fiber loops on the bottom right arm end broke. Since I have a batch 3 with the super strong injection molded connectors, I designed a repair to allow me to retain the original hoop connector. I downloaded the .stl of the arm from GitHub and chopped off about the last 3 inches of the end to use as a starting point. (Notice the triangles in the second picture from expanding the bit of arm in TinkerCad to 45mm
) Here are the results:
Here is my .stl file:
arm retrofit v3.stl (117.3 KB)
The M3 bolts that go through the injection molded hoop connector are 25mm stainless steel, and I purchased them from https://www.albanycountyfasteners.com/ For that matter, I have replaced almost all of the M3 and M4 bolts on my X4… the salt water at the beach was causing the steel ones to rust.
Happy flying!
Thanks, Phil, I also really like the evolution of your beach cart. Nice!
Thank you so much for this! I exploded a lower prop on friday, which broke one of the plates on one arm. I didn’t want to hack off the good one just to fix a broken one. This looks like a perfect repair for me.
Hi. Looks great! I’m just half way through my batch 4 build: can I ask where you got the second main switch from? (I presume its the one which has 2 positions so it will operate the pre-charge?? ) but do I see a seperate pre-charge push switch???
This summer my Batch 3 unit developed a problem. It would disarm itself…seemingly randomly. Upon re-arming, all, some or none of the motors would work (this was random too). Fortunately, none of this happened in the air. It took quite a bit of time to troubleshoot the problem, but I managed to track it down to an intermittent short in the throttle cable. I clipped the ends off of the old cable to reuse (it would be nice if the controller and throttle board had solder pads like on my quadcopters … it would make for a more robust build, and we would not be limited to the “plastic” covered wires). I ordered 24 gauge silicone wire…it had good reviews on Amazon and ordered 15mm conductive cloth fabric tape for new shielding. Here is a photo sequence of the build:
The unused IC socket near the bottom of the throttle board helps to hold the new cable tight. I did also add lots of heat shrink, split wire loom (1/8" and 1/4") and a bit of hot glue behind the cable where it goes through the throttle cover. I also added a bit of foam weatherstrip inside of the cover to help hold down the tiny 4 wire throttle connector. For me, solder pads would have been preferable.
I’ll add these photos to my build album for reference.
I’m so excited to have my X4 back! Happy flying!!
The new throttle cable works great! My swarm of “angry bees” is back!!! ![]()
I took a short flight from our local airport here in the Delta to test the repairs, temperatures, etc. I really trashed my X4 in early May when I aborted a takeoff at the Florala, AL airport. The throttle seemed to be having problems on that launch.
Here in the Delta, I have to use the paved apron at our airport most of the time, and it is relatively small.
…but I guess it will eventually make me a better pilot. Now that I think of it, our LZ at the beach is not very large either, but it is way softer that rough asphalt!!
All of the fields had been harvested, and they were all dry around the airport, so I could have put down anywhere…a great place to test the unit. Here is the flight (btw: please post your flights from time to time. I look forward to them on the community forum…I know Phil (Voltair) is good about it.) Thanks!
