SP140 first flight experience - Light weight pilot
Thanks. I have the 1 Hr battery, as the 1/2hr battery isn’t going to be in stock until March.
Im a little confused about the foam trick you are describing. Sounds like you stuffed foam to the bottom of the harness and created some space from the hardness to the cage? How does this help change the hang point? I thought the hang point it all about balance and where your weight is VS the weight of the heavy components of the paramotor. Hence why I tried to relocate the battery.
