Has anyone designed a 3d printable case for the new PCB board?
Also does anyone know voltage range for this board? I’ll be using 14s 58.8v.
That should be fine. It is rated up to 60v input
Minimum is 12v
The built in voltage regulator can output 1 amp @5v
Great will give it a try then.
