A year ago a battery fell off the seat in my car and landed on the floorboard on a small pebble that punctured one cell. Battery Leak (puncture) - source for a new cell? I discharged that battery and stored it in a fireproof box until I needed it (actually I didn’t notice until after I flew with it).
A month ago while I was flying I lost one cell in another battery pack. I didn’t notice until I had landed that the packs were extra hot (compensating for the lost voltage). I decided to rebuild the pack using a spare cell from my prior pack. I took some pictures along the way to do this quick write up.
Warning: We all know that LiPo’s can be dangerous, be careful! Never short the tabs of the same cell (i.e. use plastic not metal tools when manipulating the tabs while soldering).
Open the pack from the bottom
Remove tape and foam
Unsolder wires
Cut welded tab connector from bad cell (as close as possible to the bad cell)
Peel cell off pack (a little heat from a heat gun softens the tape adhesive)
Get your new cell and use prior solder to resolder wires (I used a high heat soldering iron to quickly solder without allowing too much heat to move into the cells)
Depending on the cell you are replacing, you may be able to fold the excess tab over to solder the tabs between cells together (using the solder already present). I had to use aluminum flux to solder one pair of connectors together. Make sure you solder the cells in reverse polarity (i.e. in series, positive to negative).
Use polyimide adhesive tape to layer protection between the tabs of each cell and tape it all together with the foam.
Use battery pack heat shrink to wrap it all back up.
Check the pack and cell voltages, re-balance the pack.
I sourced all my materials from Amazon:
- Aluminum solder and flux: https://www.amazon.com/gp/product/B010UMSB9Y
- Battery shrink wrap: https://www.amazon.com/gp/product/B07FXL9K1F
- Polyimide Adhesive Tape: Amazon.com
- Soldering Iron (really it is too big, but made quick work of the solder): Amazon.com
