X4 Cut Out at Full throttle EVERY TIME
Is the X4 designed to cut out (surge protect I’m guessing) at full throttle?
It has cut out during every attempted takeoff and went back into “Disarmed Mode.” Beeping at me as I fall out of the sky 15 feet off the ground.
4 x Bonka 7S1p
The throttle itself has taken a decent beating now and will randomly stick. Not sure if I will be able to find the parts to build a new one. Any help with this would be appreciated.
Do I put a physical limiter on the throttle trigger to prevent this?
Not sur about why your throttle goes into disarmed mode, but yes you can still find parts to build a new throttle.
A while back I build mine using a servo tester, wired to all four motors with homemade “Y” connectors. The servo tester was then wired to a trigger throttle like the ones used on e-scooter (it works with a hall effect sensor). Plus it had a on/off switch that was use as a kill switch and a voltmeter to read battery SoC.
