Can anyone provide a strong reason for X4 as to the pros or cons of using twisting wire connector caps to join the motor wires and battery wires as opposed to soldering them?
Thanks,
Jeff
Thanks,
Jeff
The wire we use has very fine strands which would break apart with a twist on connector. Because of the high amps, only the best connection should be considered. It could cause lots of damage to your equipment and/or be very dangerous.
Thanks for that insight! Okay… I guess I’ll go buy the solder iron!
