Was looking for something else in my old files when I came across these photos.
During a flight a 3D printed connector snapped and a loose hoop section did the rest.![]()
Another time, another flight, a 3D hoop connector snapped during takeoff because the hoop tube ends widened/deformed over time and many flights. The very tight net created too much tension one the cage; one tube piece flew into one propeller and snapped the shaft coming out of the motor. I didn’t even know it had happened. I heard a different noise while running in the sand but continued accelerating and tookoff. Little I new, I was flying on only three motor. I guess redundancy is a good thing.
I remember the slight right pull in flight but it was not bad. I flew about 40 minutes in ridge lift, landed, put the X4 on the sand, turned around and cursed at the skies!![]()
If you look at the photos, the hoop is missing one section.
A light but strong frame/hoop and connectors are of vital importance.
