What is a normal cell delta V?
My last two flights I flew to battery cutout as I’m still testing the limits of the battery and was a little surprised at how short my flight times were. The first was 41 minutes to cutout and and second was 39 minutes to cutout. For reference, I’m 150 lb, 4kWh battery, 16m Viper 4. Both times when I started recharging my battery, I hopped onto the Smart BMS app to take a peek under the hood and noticed that pretty much every cell had nearly the exact same voltage except cell 5 which was about 0.3V less than everything else on both flights which seems like a lot considering how close everything else is. I’m wondering if this is typical? Do I have a bad cell? Is this lower cell triggering the cutoff prematurely? Is there any way to fix it in Smart BMS? There seem to be a lot of cool settings to tweak on Smart BMS, but I don’t know enough about this stuff to start tinkering. For example, that “Balance” toggle on the first page looks like it might be something, but I can’t find any documentation as to what it actually does or means. Does anyone have any insight to tweaking things in Smart BMS?
Mine were all pretty close. I didn’t have any that were that far off. On two different 4 kw batteries. I’d be interested to know this as well. Also if theirs a guide for the app anywhere.
Also, I’m 190 lbs body weight with additional 12 lbs of instruments, reserve, flying Roadster 3 26 m. My longest of 3 flights has been 43 minutes with no cutoff yet. Other two flights I landed due to conditions.
I’m still trying to figure it out too because I haven’t found any instructions. Mine came with the maximum delta set at 0.05v and my cells have been staying within 0.035v so the balance function has never kicked in. I believe the balance only kicks in during charge. If you start with all cells close to the same voltage then you should end with them close to the same voltage unless you have a bad cell. The BMS will shut the battery down if one cell group gets too low and won’t start again without a reboot.
The ESC will cut the motor if the total voltage is low but if you let off the throttle then apply throttle again it will start back up. That’s what happened to me after a 49 minute flight. I think if I flew more conservatively I could get closer to an hour. I weigh 195 and fly a large Skywalk Tequila paragliding wing. Many paramotor wings are reflex wings which fly faster and consume more power per hour but not necessary more power per mile.
What is your delta when fully charged?
Did your BMS cut all power to the system or was it the ESC that just cut the motor?
I don’t think that is actually a toggle because it doesn’t toggle when you tap it. Next time I charge my battery I’m going to set the delta tighter to see if that icon turns green on its own.
You could sent your balance charging start limit lower to like 3v from 3.8v that should work on balancing that cell group out.
This effect occurs when 1 cell in the cell group is broken or has no connection to the group. clearly it will manage a bms or a balancer. the effect still occurs when discharging always the same. since I know the cells well for years, it is purely mathematically also so testable who wants to recalculate it mathematically. you can practically check it even if it is a certain effort. you open the battery and disconnect the bms. when the battery is fully charged you discharge each group of cells individually. you will find that (just as an example) 23 groups each supply about 20 ampere hours to 3 volts. 1 group will only deliver 16 amp hours to 3 volts. i may be wrong, but i would bet that this is the case. if you don’t do something about it, the cell group that is weak will soon fail completely because the cells are constantly overloaded by a higher c rate.
The lowest delta setting the app will accept is 0.020v. I set mine to that then during charge the balance icon turned green every time the delta went above that. This confirms what I suspected about it not being a manual toggle.
Notice the delta voltage and the balance icon in these pictures:
IMO 3.3V open circuit (after resting) is going a bit emptier than you’d want to for most applications. It shows the state of charge is really <5%. I know we want to get the most flight time out of the pack but that’s not great for the lifespan, and it means you had really no reserve.
At 3.0V I’d start to consider the cells are at risk of damage.
That said I don’t know exactly what cells are used for the SP140 - anyone know?
Why is 1 group lower? It’s probably just the one with the lowest capacity, and the cells are “top balanced”. The BMS should have cut off discharge based on this group. Generally you do see more spread in voltage at “empty”, although the rest are really tight, as you can see the voltage takes a knee at that level of SoC so a small difference could explain it.
What Bratwurst said is worth checking though - if you did have one cell disconnected it would show up like this, although it should not be able to happen and would be a major issue by itself.
From ShieldSquare Captcha
Good question; hadn’t thought to check that before. With a full charge, my delta is 0.05V, with cell 5 being nearly exactly the same as everything else.
I haven’t experienced just the motor cutout; only a full cutout of the entire system on 3 of 3 flights where I intended to find the limit. You’re saying that you’ve had the motor cutout but the system is re-engagable just by reapplying throttle maybe at a lower power setting? That seems like the ideal failure mode — each time mine has cut the motor (reapplying throttle does nothing), then the screen says “BATTERY DEAD” and then within a second or two blanks out.
Yes, I’m sure I could get an hour on a properly sized non-reflex glider. Ironically I sold my Rush 5 to get the funds for the SP140, haha. The Viper is just as efficient as any other appropriately sized reflex glider I’ve flown, but the Rush was a full 30% better on fuel consumption on my 2-stroke from an endurance perspective.
Thanks for chiming in, @Pdwhite ! As suggested, I adjusted the “charging start limit” to 3.0V from 3.8V and flew to cutoff again yesterday with pretty much exactly the same result. Prior to flight, the maximum delta between cells when fully charged was 0.05V with cell 5 being nearly the same as everything else, but when I hooked it back up to the charger post-flight, cell 5 was again 0.3V lower than everything else, with cell 5 being the sole outlier. As @evan mentioned, if the cell delta V increases as the battery gets closer to dying and if no one’s actually flying to cutout, then maybe this is normal?
That being said, I was watching one of your videos where you said that you usually don’t fly below 70V and that the battery protects itself with a cutout at 60V but I was well above each of those limits when my battery cutout. Has the cutout limit changed since you made that video (the 50 min typical flight one)? Would flying a more efficient glider let you dip deeper into that voltage range before cutout? Also, what exactly did I change by adjusting the “charging start limit”? I really know nearly nothing about these batteries and presumably the settings are there for a reason (?). And finally, is it actually that bad for the battery to be run to cutout? I assumed that the cutout was set to protect the battery before I could hurt it?
Thanks for putting together such a cool project! Im sure you’re swamped with current orders and such, but it would be very cool to get a video or something on what different BMS settings mean and what we can safely do with it at some point.
SK, from your description, the BMS shut the power off, and that will have been based on individual cell group voltage (probably your group 5) rather than total pack voltage.
That’s the whole reason to have a BMS, because otherwise you wouldn’t know that one group was empty, and the ESC would just keep on pulling current - it will quickly go down below 2V (killing it) or even be forced to a negative voltage by the other cells in series. That’s when you get a “thermal event”.
So the good news is the BMS is doing its job although, the way it cuts off power without warning isn’t ideal.
What you need to figure out is, is one of your cell groups significantly lower capacity, or less charged than the rest, which is shortening your run time?
To check that I would do a ground test. Secure the frame to something, and hold the current steady at (say) 50A. Time how long it runs, watch the BMS app and verify the reason it’s shutting off, and record how long you get.
For example if you got 30 minutes, you know you’re getting 25Ah at that load.
If that’s below the expected range, then the question is, is that cell group weaker, or just not fully charged for some reason? That’s what the balancing function in the BMS is for. However it can only compensate by bleeding off a very small amount of power from the highest cells (all the rest in this case!) to bring them down to match the lowest one, while charging (and above a set voltage as Paul explained).
That can take a very long time to balance out, and you’re hammering that low cell group every time you use it, which will actually cause it to lose capacity.
One remedy is to manually balance the cells (just charge the affected group with a PSU when the normal charge is complete), and if it really was just unbalanced then the problem will be solved.
I would not recommend a ground test… That can be dangerous if not properly secured. It’s a lot easier to attach your phone somewhere to monitor the app during flight than to attach your motor to the ground. The rest of what you said is accurate and very good advice.
His description of has last flight answers this question. When the pack was fully charged it was balanced within 0.05V. When he landed he had one cell group 0.3V lower than the rest. That is not a normal delta at all and since it started balanced it points to a capacity issue.
When I fly to cutout or near cut out my cell groups maintain their balance which means all of my cells are equally healthy and have equal capacity. It is not normal to be 0.3V different at the end of a flight. That’s quite excessive, specially if you start with all cells within 0.05V.
The BMS only balances the cells during charge and normally towards at the end of the charge. What you did was initiate the balance earlier so that it had more time to bring the low cell group up. It just helped to guarantee that your delta was good at the end of the charge and the start of your next flight. Unfortunately it got off significantly by the end of the flight. Therefore it’s not a balance issue… you have a bad cell group. The BMS will continue to protect that cell group by shutting down the pack. The other 23 groups aren’t getting fully utilized.
Yes. The voltage of my pack got low enough that the ESC cut because of low pack voltage. Definitely a more ideal warning, however the pack was so empty that I couldn’t maintain level flight.
What you experienced was the BMS shutting the battery down. It’s basically like unplugging the battery.
I recommend flying with your phone mounted so you can see the lowest cell group with the app. Then you will have that visual warning before it cuts. That’s the best “fuel gage”.
GP, two comments to add:
It would be near impossible to maintain an exact current setting while flying. Surely it’s possible to secure the thing properly with a bit of care and some 2x4’s?
Second, as you say it probably isn’t a balance issue as they seem close enough to start with. But the other cells are almost empty at end of charge too, going by the resting voltage, from my experience. He could just be using more energy than expected.
We do have cruise control.
I agree that analyzing on the ground can have its benefits but the app is a pretty powerful tool that can be used in the air and there aren’t other instruments needed which would require being grounded.
Yes, there are safe ways to secure the motor on the ground but there are a lot of unsafe ways to do it as well and I’m sure those ways would be discovered by someone if we go around recommending that. With gas motors, ground starts are highly frowned upon.
I also agree that if the cells are close to empty they will drop off faster and potentially make a bigger delta at the end if one group hits that steep part of the curve first. A simple check would be to fly with the app and see what pack voltage the delta starts to become excessive. Or he could fly till the pack is low but stop earlier than he has been stopping and see what the resting voltages are. I bet in his case it will start pretty early based on how severe the delta has been.
Fair enough, I guess what I’m getting at is it would be useful to record exactly how much Ah he is getting from the pack, if it’s in question at all.
The instrumentation supplied can’t really do that so it’s why I suggest a fixed current run down test. Obviously to be done safely! I think I will do that when I get mine anyway (and/or add instrumentation)
That’s cool… I’m sure you understand more about it than most people. What instrumentation are you wanting to add?
The throttle controller displays kWh from the ESC. Not sure how accurate it is but it should be pretty accurate if you operate the throttle smoothly. Also, the ESC records a couple hours of data which can be downloaded.
Building batteries and BMSs, and integrating them is my day job so please forgive the nerdery!
I would like to have an accurate Ah-based percentage display on the controller. Plus a warning and few seconds grace before you hit empty. As you said it’s already displaying kW and kWh so the ESC data contains enough to do this without adding any hardware.
The BMS app looks good for diagnosing things, but ideally end users shouldn’t need to be in there worrying about balancing and cut off voltages.
Maybe I’m making too much out of this but I read a lot of stories with people having cut-outs in the air and kind of guessing where the limits are. SP140 will be my first paramotor after paragliding and I won’t be as competent a pilot as some of you guys, so I’d rather work around the avoidable issues like that. If I can contribute to the project usefully, I will.
@evan , thank you for the very detailed explanation. Let me just make sure I understand what you’re saying: By my math, the battery should have a capacity for 40Ah, and the implication of what you’re saying is that Ah is the best measure of the battery’s capacity (do I understand that part right?). If I can run it at 50A for an 48 minutes (40Ah/50A x 60 min/hr= 48 min), then my battery capacity is fine and my expectations are off. If I can’t get the full 40Ah, then there’s something wrong with the battery. Is that right? Should I expect to get the full rated Ah of the battery? I’ve been getting about 3.3-3.4 kWh of battery but maybe I souldn’t expect to get 4 and Ah is a better predictor of capacity?
As far as testing, for the sake of control, it would be ideal to ground test, but I’d have to go out into the middle of nowhere to not annoy the neighbors, and at that point I might as well fly, haha! So maybe I could just do a 500’ climb, then set cruise control and run it out which I imagine would be close enough to get an idea of where I’m at. And as far as losing power, as long as I know it’s coming, I’m pretty comfortable running it to cutout from a flying perspective. The last two flights, I suspected cutout would happen sometime after 30 minutes, so I made sure to just loiter a few hundred feet over the LZ until it did. Even on my gas unit, I always do power off landings, sometimes with a dry tank.
The next thing you mention is that it’s possible to rebalance the lower cell group just by a series of discharge-recharge cycles? This would be great if I could just have the pack “self-repair” rather than have to send it in or whatever I’d have to do to get it fixed, but that seems kind of like magic to me that that could do it.
However, it’s still curious to me that the “bad” cell group delta is ~0.05V from everything else when fully charged and even when I brought the battery up to a storage voltage of 86.4V after my last flight running to cutout. Although, as you guys seem to be saying, it’s possible that the BMS is able to even it out when charging but not when discharging, if I understand correctly. In that case, I think I’ll try what @GliderPilot suggests and monitor the BMS in flight and see what that cell is doing. Obviously, I don’t want to be watching that app every flight, but for a test flight to see what’s going on, it’s easy enough. Is there anything I’d be watching for other than seeing whether that cell group is low throughout the flight or just at the end?
