SP140 on a Air Conception XL frame
How difficult would it be to mount the SP140 on an air conception frame? I am a tall guy, and can handle the unwieldiness of their XL frame. Is the SP140 constructed in such a way that you can just throw it on different frames?
Paul, Would a 130cm really be a “loss of efficiency” or would it just be a loss of peak available thrust? Many people aren’t going to need the full output thrust that the present combination is capable of. For example, users happy with Atom 80. If a smaller prop is used, and less thrust is needed, then less “work” is done by the motor, so doesn’t the power consumed by the motor also drop, and run time increase? I’m only now looking into electric and a friend has purchased the SP140, soon to be delivered.
