I’m struggling to believe that the charger could fully charge a 4kw battery in 2.5 hours on a 110 volt outlet as that could take upwards of 18 amps with transformer inefficiencies and most house breakers are around 20 amps, but I guess it could be possible. I personally think it’s more likely that they are using a 220v outlet, but this is all speculation
As for charging other batteries, this charger is basically a glorified power supply. The paramotor battery has a built in BMS so it doesn’t need to balance the battery or even have a cut off built into it. With this in mind, I doubt that it could charge your other batteries.
Yes bob is correct, the charger is a 10a 100v power supply basically. So that would be equivalent to a 1kw so for a fully discharged 2kwh battery it would take 2 hours. And same with the 4kwh if it was fully discharged, it would be 4 hours.
We could do a 20a charger, but it might be a problem for some as you can use a 110v outlet, and some don’t have the 20a outlets, 15a is pretty common in the US. But if some of you guys want the 20a faster charger they are sorceable as that is what i used for awhile. Id did have a tendency to trip my breaker if I open the garage door. But i like this newer charger better as my routine is bacily fly in the evening, either plug it in over night or if i see the weather is looking nice the flowing day i plug it in after lunch. Or i leave it charged. Also this newer charger has a screen that show the voltage,amps, and indicating lights to show when its charged.
The charger is just a slightly more intelligent power supply, but you could use any 100v power supply as the battery does have its bms built in, and its rated for up to 80 amps of charge current. So you could charge the batteries up in 20mins for the 2kwh pack and 40mins in the 4kwh pack. But that wouldn’t be safe for the 2kwh pack as that would be over the max charger rating for the cell (which is 6A), So if you did have a very beefy power supply, the max time you could charge up the 4kwh pack would be 40mins will still being under the manufacturer’s safe rating. (you can see specs here https://cdn.shopify.com/s/files/1/0697/3395/files/samsung-40t-datasheet.pdf?6001754416888422053)
Now I wouldn’t recommend that as that would decrease your cycle life a lot, so that is why i think the 10a as a sweet spot, as it maintains battery health, and isn’t too slow as to get annoying and is compatible with most households.
Is it supporting 110 Volt (US) only or also 220 Volt as commonly used in Europe?
Many modern power supplies will support both out of the box, but getting a confirmation from you would be good.
Ya depends on the manufacture and chemistry, “lithium” is a broad category. I would look at the datasheet on the cells. But generally the slower you can charge the better. I have charged at 1c and didn’t measure a significant temp increases without any active cooling just depends on the cells specs.
Can you also share the datasheet/specs of the BMS used in this battery? I’m figuring out a solar-based DC-DC charging system for these batteries and need to know BMS limitations (voltage spike protection, current, cutoff, etc)
2170 / 24 = 90,416…
I might not be up to date with the latest battery tech when it comes to things like spare cells in large blocks, but I would expect an even number, e.g. 24S-90P = 2160 cells.
Also I expect less cells in total based on the weight of the single cell. If I read the SAMSUNG SDI specs of INR21700-40T correctly that is 70g each. 2160 cells would weight 151 kg / 333 lbs.
We would have a hard time doing any kind of launch launch with that weight
For the perspective check out the launch of Lauri Kadakas with 70 litre of fuel (18.5 gallons) on his 1130 km / 702 miles distance record flight. It is doable, but hard.
@Pdwhite
Brining up my question from Sep 16th again:
Does the charger you plan to ship with the SP140 support 220 Volt input?
If this is not the case we cannot use it in Europe.
Does the charger offer controls or logic for measuring the battery status and turning off when the battery is fully charged, or do I have to monitor it?
“the charger is a 10a 100v power supply basically” does sound very basic and that is would require manually interrupting the load process right after reaching the target load level.
Please share some more details about the charger.
An example / some pics would be nice as you probably already have a bunch of them ready for shipping with the rest of the pre-ordered SP140 units.
There are 2 different models i have got the 110v for the US guys and 220v for the EU guys.
The charger is automated so you just have to plug it in and it will do the rest. It is set from the factory for the cell curve. Then also the bms is there for backup and it also shuts off for max voltage.
So the BMS built-in to the battery has some sort of MOSFET that shuts off the charger completely if the max voltage is exceeded? Does this happen at >4.2V at any cell or >100.8V total?
