After MANY many years of wanting and EPPG, and many months of delays due to shipping damage and parts shortages… I finally got to first flight my SP140 2 days ago with my Sirocco 3 24. I’m putting this in the Throttle Controller category on the forum because that’s the main issue I had…
Overall… I love it. The ease of setup and lack of having to deal with gas and oil is as awesome as expected. Plug and go is the way. Made my gas buddies jealous when they were having starting issues on a Moster.
Noise: Not as quiet as expected when on throttle, but not surprising. I’ll have to remember the ear protection going forward. The silence when off throttle is golden.
Comfort: I’m light so I’m a bit pressed forward after setting the hang points as far back as possible and adding webbing behind the seat back to add a bit of spacing. Overall no worse than other motors I’ve flown in terms of arm angle. Harness is great otherwise. Hopefully some redesigned arms will help us light folks with a better hang angle, but with the thrust line as high as it is, I didn’t find the hang angle bad at all once I was flying despite it being around 17 degrees on the test hang. Getting out of the harness and forward for landing was slightly more difficult than I’m used to just due to hang angle, but once my foot touched it was no problem standing it up. Having the weight so high on your back makes ground handling much nicer, friend who tried it said the same.
THROTTLE LEVER: This is my main issue so far and what my thoughts focused on most of the pre-flight and flight. I used CHILL mode the whole time, so keep that in mind… but most of this applies regardless of mode.
The lever arm offers almost no feeling or resistance feedback and is too easy to press. While wearing thin gloves and grabbing risers and toggles, I bumped the throttle multiple times… My buddy flew it after me and did the same. I can’t imagine it with thick winter gloves, you wouldn’t be able to feel anything. In the future I won’t be arming until wing is over head to prevent accidental spin ups until I sort a better lever arm solution.
It is also difficult to find a brake toggle position that allows you to hold the brakes while not bumping the lever because the pressure is so light and lever is long. Again, with thicker gloves this will suck more. Open to suggestions here but I tried 1 finger, 2 fingers, all 4 fingers through the toggle and all seemed to bump the lever too easily while gripping. The obvious solution would be brake toggle on hand first then throttle, but this is also obviously a bad idea. I’ve used the Polini throttle for years and it’s by far my favorite, so I’m not new to this configuration of throttle. It offered good resistance and feel while not being in the way, possibly because the grip was much thinner. I’m sure I’ll get used to this with more flights and tweaking.
SOLUTION ideas:
A. Make the throttle lever half as long. This would get the top of it out of the way of the brake toggle making it harder to accidentally hit, so you can hold toggle with top to fingers and trigger throttle with bottom two. I know someone else on the forum did this already. I’ll print another lever and try it out.
B. Add a spring over the plunger. I’ve played with this and it helps a ton with resistance feeling on the bench. But it will also shorten the throw so you might not get full throttle … I have to test it plugged into motor to check. Hopefully I’ll have time to model up a modified lever with spring cup and shorter length soon. This could be fixed in software if spring prevents full throw of plunger. Maybe a clothespin or carabiner style spring would work better… will have to look at it closer.
THROTTLE CURVE: Wonky in chill mode. The lack of resistance feel on the lever doesn’t help, but the throttle curve could use some tweaking. Again I only tried Chill mode so this is limited to that mode. But, I was struggling to find the sweet spot to foot drag as it was just too sensitive. I would LOVE a software solution that would allow us to tweak a visual curve and save custom modes to the throttle. How amazing would that be to be able to tune the curve to your liking. I’ll give the SPORT mode a go next time and see if that helps as I imagine it’s way different.
Overall I’m in love. It’s so close to perfect given the available battery tech. A few tweaks on the throttle stuff and I will have nothing to complain about. Thank you to everyone who put time in developing this thing, it’s a work of art as far as I’m concerned.
-Loren
(Yes I accounted for the fact that the nipple at the start of the throw in full open position will press a bit on the plunger… but not enough so I still had to shave off a mm of material on the bottom outside of the lever where it contacts the throttle body so it can open fully and not press any throttle. When I first tried it and armed the throttle it was ever so slightly pressed so the motor started spinning immediately … no worries no prop on*)
