Ouch – that stuff is expensive – and they state low flammability so it has to get really hot to burn?. Cost wise better off to go with Alu in my opinion if your concerned - so far there has been only 3 people die from bat fires , kidding - ZERO battery fires in the OpenPPG community or Etrikes or Eflying anything that I know, someone correct me if I am wrong. Not saying impossible - just highly unlikely, I guess once Eflying is more numerous than more likely.
I like the idea of the cover over the controller battery connectors but for a more industrial connectors – they look pretty robust for the application.
I dont think having different spar colors just for length mark makes any sense, neutral black beats out a rainbow frame for most.
this would be a nice to have, that or maybe a tiny strip at the ends of the spar, but definitely not the entire spar.
That said, maybe in the future having different color spars in stock could be a thing to get as extra for color customization But this would be like a set of all black, or white, or red, or blue, or fuchsia O.o etc…
for now I just sharpied S,M,L on the frame pegs. I see myself taking apart and forgetting which goes where. would be interesting if it was just a small ring at the base of the spar.
I should clarify, the .1" pin connectors to the throttle. would like to see those with a locking connector and be more robust. I’m not harping on it, but I can see the potential something knocking it and breaking them off. Either a cover or stronger connectors.
@Pdwhite I was measuring Braedin’s frame and figured out that if the spars were at slightly different angles than how they are now you could make them all the same size. Is that a revision you would be willing to make?
