Seaside ops, corrosion, and preventative maintenance
I fly off seaside beaches and along coastlines mainly. Has anyone had any issues with corrosion? Are there any additional preventative measures I should take with the motor and electronics after flights in sea spray conditions? Thank you!!
I think @Voltair would be the seaside flight expert to ask :eyes:
Never had an issue other than the mounting bolt heads from Batch-1 (the original series) getting slightly corroded. The new bolts Paul has on his machines are stainless now I believe. Zero maintenance after flying the original SP​:smiley:
just saw this. Appreciate you getting back to me.
