Propeller Bolt Torque
I’ve reviewed the new 2.5 manual and it fails to include a section for mounting the propeller.
Does anyone know the required torque for the tri-blade 140 propeller?
I can assume it would be like the Vittorazi propeller bolts;
**between 10 to 12 Nm (Newton meters)… **but I wanted to be certain.
FYI I will be using the quick release, but I’d like to have the numbers should things change.
It depends a little bit on the propeller use, but with the E-Props propellers, it’s around 8 to 9 Nm.
Paul, you are on it, man.
Thank you for the quick reply!
