Hello people,
I have received messages here and also by email directly about motors that would be possible for a trike, even with a lot of continuous power if you have a lot of batteries with you.
I personally don’t deal with 24 S setups, so I have no experience with long-term tests or efficiency tests with different EPPG variants.
but basically it’s pretty much the same as with 60 volt systems. 2.5 to 3 kilowatts per kg of motor weight are realistic with good cooling.
I have seen that there are custom motorcycles that weigh around 5.1 kg and a kv that fits well with large propellers around 140 to 150 cm for a trike.
The link is only a suggestion for anyone to look into it. Best regards
