What side would you attach the hang points and would you need spacers to offset the torque and on left or right?
Yea i see the normal way to setup, if you instal the factory R or a gas motor prop turning opposite the electric motor the swan arm offsets should be on the opposite side? is there any spacers for the arm and frame?
The electric and the Moster 185 spin the same direction so the setup is the same. The only torque compensation is the offset hang points. There aren’t any spacers.
Ok just tried to take off and seemed like a lot of torque or pull to the right …So offsets should be on right side facing forward swing arms med/low hang point’s (Its got a triple prop)
