It looks as if you replaced the cable but kept the original small connector. That connector could be loose. You may be able to remove each socket from the plastic and pinch them tight then reinsert them. Or solder the wires directly to the pins.
Yeah I kept it. Would have been best to replace this connector and pins. It’s tiny, can’t even get paper lip in these connectors. Would be better if this was normal size jst 2.5.
I have feeling issue is with the control board otherwise why wouldn’t the motors go into disarm mode when throttle is pressed. Only happens when motors are not spinning but motors are armed. You would think vibration would cause it to lose signal and flip into the disarm mode if it was the cable.
I ordered the avionics upgrade so will replace it all with the newest board, controller.
