I’m trying to mount the x4 on a skycruiser trike. While doing that I realized that the hinge between the top and the bottom is not locked and can move with some weight/pressure
To sit in the harness in the trike the pilots weight starts bending the top frame forward
I can’t figure out if there is any built in mechanism to lock the hinge. Do I need to stick some pins n the holes that I see in the picture attached? Or is there something built in that I’m not seeing
