So here is a really good deal for someone wanting to build their own lipo battery pack, you could incorporate a bms into the pack as well, much safer with bms to cut power if temp gets too high or pulling to many amps.
Very interesting. Simpler to put together than I thought. I think I would go to the extra effort and solder the tabs directly together.
They are 8AH cells rated at 200A cont
At 8AH you would need to do a 4P(32AH) so 4 packs of…13s? + 4 BMS + a chargers… This is adding up fast and you need to to the all the labor.
Crusing we draw 100amps??? 30min flight? correct me if I am wrong.
