Issues or upgrades for 2y old setup?
I’m getting back on my (new) 2y old rev1(?) ppg.
Are there any must have updates or fixes I should do?
I’ve noticed the cage spars don’t set really nice and wondering if my lengths are wrong. There’s maybe a cm on a few.
I had to move the hang points far back (180lb) and notice newer arms looks better (upgrade?)
I’m running orig fw on controller. Should I update?
There are 3 different lengths of spars. Make sure they are in the right position. Medium on top, then small, then large on the bottom. It’s ok if the spars seem a little short as long as they have good engagement with the studs… that actually allows the hoop connectors to fully seat. Longer spars can interfere with the hoop connectors fully seating.
The new arms are nice but not necessary for your weight because you shouldn’t have issues getting the hang position correct. If you plan on doing high G acro then you should upgrade the arms.
If you don’t have issues with the current firmware then just leave it how it is.
