I’m extrating DXF template in order to cut my first batch
but I’ve seen an error in SW design
the body goozeneck bar attachment looks to have a hole not concentric with main top plate and looks to have a collision with the top main plate
Hi, i just checked the STEP files and they match OK . I do not know about the solidworks, as i cannot open them…
I’m also working on parts but i fabricate the hinges now…
Attila
ok thank’s
can you please told me the good distance between the both holes and the distance between sides of opening for goosnec attachement I will coirrect the swolidworks files accordingly and make a pull request
I’m also working on metal parts to be printable with fdm
I’ve been forced to reassemble (re-mate) all componnents but I found another strange thing in sw model looks that one of arms ave a larger hinge fixation holes than other in front main plate
51 mm between 2 front hole
main plate.pdf (85.3 KB)
