I’m hesitating between the two harness sizes. I know there is an open topic about it, but without clear conclusions. At 175cm and 76kg (5´9" and 167lb), what size do you recommend? Thank you
I’m 183cm and 70kg, I went with the M size with underseat reserve, it’s great! ![]()
Good to know! Thank you
I’m 5-9 180 and medium works fine for me.
you are almost like me. S/M size seems the way to go.
Parajet uses the Dudek harness and I was told by a rep at a fly-in that the L/XL is only for people with very long torsos. The width is the same for both sizes. He was 6’ 2" and used the S/M. I am 6 feet 170# and the S/M worked for me.
