I normally build e-bike batteries and was interested to see if I can build a robust (for 300amps) 3 x 14s7p hooked up in parallel and then use them individually so I can use them for my e-bikes as well.
Here’s what I’ve found so far:
18650’s: EV West - Electric Vehicle Parts, Components, EVSE Charging Stations, Electric Car Conversion Kits - on sale for July2019 $630 for 200 of them!
3000mAh and 15A → 30a peak up to 80c
connect them up with these: Customized Nickel Welding Plate Copper Strip For High Current 18650 Lithium Car Scooter Battery Pack - Buy 18650 Copper Strip,18650 Welding Plate,18650 Copper Welding Plate Product on Alibaba.com
Use copper terminal rings: 10Pcs 200A Kupfer Batterie Kabel Stecker Terminal Crimpen 16 35mm2 Draht OT 200A CRIMP TERMINAL|crimp terminal|cable connector terminalconnector terminal - AliExpress
I use this to weld: DIY Arduino Battery Spot Welder Prebuilt Kit V4 - Malectrics
If I continue with this sport I’m going to attempt to build a 18650 battery.
Hope this helps someone
). The solder connecting the diodes melted as they got too hot. Once I found the error of my ways, they worked much cooler.
