Can someone who’s working with the design files please provide the dimensions of the space available for the batteries?
The 3D files are for the aluminum hinges, outer rim tubing and carbon frame parts only.
The four motors and propellers are not included, and their size and position are unknown.
so it probably does not help much if these are not taken into consideration.
Yes, particularly important is the clearance between the prop and the frame. Paul, do you have this measurement?
Its 190mm from the back of the plate to the props.
Thank you Paul
