This is just a comparison of some modern paramotors to cover the technology involved and compare some specs. Many of the specifications that I will give are by the manufacture and many are calculated based on clues that have been found from various sources so they may not be compleatly accurate, but they should all be close. I am also not listing motor power because every company could rate the exact same motor differently. I am also not posting weight because it is very difficult to find an accurate weight for many of these units. For this reason I will not do a head to head comparison, but cover each paramotor separately. I don’t have a ton of time right now so the paramotors I will cover for now are the Paracel, Exomo, open ppg Sp140. I hope to add more later.
Things to take into account before we continue. The battery KW and amp rating is a theoretical rating for if the battery is completely discharged to 2.5v per cell at a very low current. Also note that not all cells are created equal. For example, we have battery A and B. battery A is built with high capacity cells and holds 4 kw power. battery B has higher current cells but only holds 3.8 kw power. But when we discharge both battery packs at a constant 8a per cell Battery A may only give 3.2 kw and battery B may give 3.4kw. This was probably a really bad example but I hope you get the point.
PARACEL(75A):
Battery energy(kw)----------3.9
Battery AH --------------------75
voltage------------------------51.8
Battery configuration----14s25p
Cell type---------------------18650
Cell used-------LG hg2(older models), Sam 30Q(up until a few months ago), ?(current)
Rated flight time-----------70 minutes
kwh needed to fly------------3.34
Cost--------------------------?
Thoughts: The paracel has a pretty good battery capacity, but 70 minutes of flight really isn’t realistic for only 3.9 kw of battery capacity. Overall is has a great build quality with great components and it should last a long time.
EXOMO(78ah)
Battery energy(kw)----------4.3
Battery AH --------------------78
voltage------------------------55.5
Battery configuration----15s26p
Cell used-----------------------?
Rated flight time-----------60 minutes
kwh needed to fly----------4.3
Cost--------------------------$14,000
I find it very interesting that Exomo uses very similar components to paracel yet they rate the exomo as needing one extra Kwh to maintain level flight. To me this indicates one of two things. The first thing it could indicate is that they are a much more honest company and they are trying to report realistic numbers for their flight time. The second thing it could indicate is that they cut back on the amount of battery capacity available to the user to help enhance the battery life span which could also explain their excellent 4 year battery warranty.
OpenPPG SP140
Battery AH --------------------45
voltage------------------------88.8
Battery configuration----24s9p?
Cell type---------------------21700
Cell used-----------------------???
kwh needed to fly------------4
Cost--------------------------$7000
There has been a lot of mystery that has surrounded the sp140 and there still is a lot. The current biggest one is surrounding the battery pack. based on the current given specs of the sp140 we know that the 4 kw pack weighs 38 pounds and the 2.2kw pack weighs 22 pounds. So if we run the math, we get the 4kw battery pack as having 33 pounds of cells. We can then run the math and based on the average 21700 cell weighing about 70g and the unit being a 24s system we get that the sp140 most likely has 9 cells in parallel or a 24s9p setup. Here is where the problems come. To get the 4kw rating needed out of 216 cells they would need to be rated at 5000mah. Now 21700 cells of this capacity exist, but none of them have even close to the 25+ amp rating that would be needed to support the M50 motor that is used. I am really curious on what Paul has to say about this but I am sort of concerned about this. Other than the battery, The sp140 was built to provide the best bang for your buck. It wont last as long as an exomo or provide the flight time, But overall it should be a pretty good paramotor.
