Can the old hand hardware fit in the new controller body?
I’m new to this and just checking to see if this could work.
Thanks
Hey Brad,
I’m not sure what you mean by old and new specifically, but safe to say the answer is generally no. With some components being moved and improved between each PCB, each case is designed to fit that specific generation of the hand controller.
What did you have in mind?
Zach,
I like the new controller and was hoping you didn’t use different components. It sounds like you did, and getting a chance to look inside both frames, I can see a big difference. The new V2.5 throttle handle looks modeled a little better than the older version.
Great job. Keep it up.
