Hi all,
I have an SP140 and was sent a new RP2040 throttle controller (with a USB-C port) to replace my old throttle controller that died. I’ve tried firmware version 5.9R and 6.0R. Both versions give me a BATTERY ERROR when I plug in a battery.
I know the batteries (two of them) are not actually the problem because they still work fine with my son’s SAMD2/CM0 throttle controller.
Is there a compatibility issue with the newer throttle controller? Does the ESC firmware need to be updated? (I looked into doing this, but wasn’t sure if I found the correct instructions, and also my laptop is a Macbook.)
Any ideas?
Thank you!
Scott
