Is there a table that shows approximately “voltage = percentage full “ and is it ok to remove battery during the charge if only partially charge is required ?
You can definitely unplug the battery during charge. That’s no problem at all. Then for the voltage versus percentage charge, you can just connect to the battery over Bluetooth and see SOC. Or another option is set a storage charge in the OpenPPG app. It’s in beta so you can sign up here for that link to the app. That’s going to be the best way of controlling your battery.
Thanks will join OpenPPG app .. also tried the Smart BMS app on my iPhone .. phone did not see the Bluetooth
Ps ok to travel with batteries flat on it sides ?
The Smart BMS app is not the correct app to use for the V2 batteries that is only used with the V1 batteries so that’s likely why you’re not seeing it.
