Hi Guys ![]()
Please Help Me With This Calculation Like–
SP140 Using This (SP140 V2.0 Battery) Battery Pack with BMS Which Size is 3.7kWh and featuring top-grade lithium-ion cells Like Molicel 21700. So Battery Configuration is – Molicel 21700, 24s, 11p, 4200 mah.
So The Battery Capacity is Total 46200 mah.
Battery Size / Energy is 3.7kWh
Battery Weight is 43 lbs.
And It’s Can 10kw continuous power rating and 60 sec burst at 20kw to SP140 Paramotor Which is MAD M50C35 PRO EEE Manned Drone 34 KV motor. As you Know It’s a Brushless Motor And It’s Features is –
RPM/V : 34 KV
No Load Current : 3.7A/30V
Motor Weight : 4205 g
Maximum Current : 251.5 A
Maximum Thrust : 113.7 kg
Hover Thurst : 35-45 kg
ESC : 300A(12 - 24S)
UAV take-off weight : 245-63"/ 160kg–Quadcopter, 240kg–Hexacopter, 320kg–Octocopter
Nominal Voltage : ? (24S lipo battery)
Internal resistance : 14.7mΩ
Maximum Power : 24987W (25KW)
Maximum Torque : 78.4 Nm
Propellers : Tri-blade 140cm
So How Can It’s Fly 40-60 Minutes What’s The Math ?
