Hello everyone
I own a first-generation SP140. It still has an ON/OFF switch on the battery.
I had to replace the battery’s BMS because the output voltage was no longer 88.8V, but only 60V.
Paul sent me a new BMS with Bluetooth. It works perfectly, even with the app. Output voltage is over 88.8V.
Now I have the problem that I can no longer charge the battery.
Is there anything I need to be careful about with the new BMS?
I have the feeling that there’s a missing authorization for the battery to charge.
I would appreciate any help.
Greetings from Switzerland
