I had a bad launch on my V1 SP140 slipped and bent the frame, and busted the hoop and prop. I just received the replacement parts, which are now V2, and was wondering if I need to replace the swing arms as well?
Yes, I received a message that the V1 swing arms are compatible with the new V2 frame, so I put them on. I am now just waiting for spring to fly again.
They use a different bolt size don’t they? I thought the bolts on the V1 are 8mm and the v2 are 10mm?
