Anyone with SP140 in LA, OC, or SD (California)
Hi all,
I just bought a used SP140 off Facebook Marketplace, knowing there was an issue with the battery. Is there anyone is So Cal that has a battery I could just plug in and see if the motor is running? Also, any help or suggestions re battery diagnostics is appreciated.
Thanks in advance,
James
(only do this if you’re comfortable) to test the motor you can also connect the battery to a ~80v DC bench-top adjustable power supply and it will spin with no prop on. Thats how I do some testing.
Thanks for the info!
