I have the net taught, but it seems after only a short while the connectors between the hoop pieces seem to separate, to the point where it might come off during flight. anyway to make sure these stay tight together? not always the same section that becomes separated.
I haven’t flown the frame yet, so no bad landings. brand new, has ICE motor attached to it.
Make sure the carbon spars are fully seated into the frame and into the hoop connectors. Also make sure the shorter spars in the correct location. If those things are good, the net should keep the hoop sections together.
To be more clear… some of the spars fit pretty tight into the hoop connectors and may need some firm pressure or tapping to get them to fully seat. The only time I’ve seen my hoop not stay tight together was when the spars weren’t fully seated.
