Add switch to original V1 Battery?
My Anti-Spark is toast. Hoping to keep the connector and just wire in a switch. Does the BMS support a switch?
Worst case I get a new BMS with bluetooth/switch and new connector but I’d rather not until I know the 4.8kw battery release date.
No, you cant just wire in a switch to the V1 battery.
But I dont think you should get a new BMS for this feature, Just replace the QS8 and be careful not to leave the connector plugged half way and make sure to plug it into the charger first before the wall and you should be fine.
If it has ben sparking often, you’ve probably damaged the female connector anyway, why do you want ot keep it? Just replace with another QS8.
