This LZ is a bit tight for an X4 batch 4 (designed for 14S) running on 6P 12S Bonkas. A little finesse is required to clear trees around here. It’s initially drawing over 250Amps at 44 Volts. This launch was also a bit weak because the batteries were not fully charged. I’d used about a minute of power doing 3 launch/abort cycles in this field a couple days earlier and didn’t bother topping them up.
