Where can i get the latest up to date files and also is there a complete bill of material (including motors, esc’s, screws… Well everything) available somewhere ?
I’ve just created an account on GitHub as it’s where things happens apparently but not exactly sure where to go at this point.
Just want to make sure i have the latest version available (as it seems like there’s some issues with holes location in some places ?).
I’m fine with either sw or step files. But having an entire assembly and/or a list of everything would be great (i can definitely make one of it doesn’t exist yet).
So I redid the hoop connectors and made the ends longer. Here are two pics of the printed results.
I have the .STL files and Solidworks .prt files but can’t upload to this site. Maybe I can get them on the GitHub.
Great job configuring longer ends to the hoop connectors, SimLoop! That was needed. I’m going to see if I can can get a set made when the files are posted. Thanks for your effort.
@davek79 , thanks for uploading the hoop components! …but I still need a bit of help.
I run Repetier Host with my home built Kossel delta, and it does not support .sldprt files. When you have time, would you save and upload the parts as .stl files? .stl format works across many printer platforms, and it is a file format that I can work with.
Sorry, Dave, the github layout is new to me…just a bit confusing. If I click on “Airframe” I get to the .stl files. If I click on the description to the right of “Airframe”, I only get the SolidWorks files. I am good now. Thanks for putting all of this out there. It is appreciated! Bill
Does anyone have a list of the “non frame” components ? I mean anything that’s not in the 3d filles like screws and bolts, motors, esc, props, nuts, connectors and so on.
Can’t seem to find it on Github.
Thanks
