250kW Motor Weighs 15kg
Interesting article about a new electric motor from H3X which claims to be 3x lighter than other motors with comparable power ratings:
Could be useful for an electric tandem trike.
here the same company : xphone Promo (Full HD) - YouTube
You nailed it @sanman.
It is only good for us to use in paramotor if they can do 26KW in 2Kg model
I have been following these guys. I have worked on some motor designs in the past. The concept of fill factor makes sense but the problem with a high power density motor is mostly never the electromagnetics but how to get the most power out of it without thermal issues. My understand is this will only get you 250kw for like 10s and likely the continuous will be more like 80kw (unlike the 200kw mentioned)
