What about the NESE module
Here is a 150A test – with shake/vibration added
NESE
NESE 200A test
His site – http://18650.lt/
Rgs, Patrick
NESE
NESE 200A test
Rgs, Patrick
With this system you have easy to connect the pack, and if single cells fail easy to replace.
VRUZEND kit cannot handle the current required here.
Wirebonding - does not look diy friendly
NESE is looking like the best to me if i were to go the 18650 route
Yeah, Vruzend looked promising, but the amp rating is too low…3.5A per cell, topping at 5A.
NESE looks like a promising option. 1S6P test by the creator handled 120A ok.
Here is a page listing various pack assembly options…
What thoughts do you peeps have on 38120 LifePO4 batteries (the first battery pack in that list)?
Had a look at Powercell’s battery pack. 810 cells!..
Now that’s a pack! Doesn’t seem bulky on the machine. Neat package. 70 minutes fly time.
I’ve got my hands on some 18650 cells that should do the trick, as long as they’re in a big enough pack to keep the C-rate down around 2 peaking at 6. Really high energy density too. Spot welding tabs will be the way to go for sure.
I’ll test those our and report back. Will be nice and compact, rigid and structurally sound…
Boys - If I were to go the 18650 route (which I consider the Pro-Build option),I’d go for these cells. Don’t buy off e-bay!
https://eu.nkon.nl/rechargeable/18650-size/sony-us18650vtc6.html
A 12S10P pack would consist of 120 of these batteries which would give you your rated max of 300Amp discharge for take-off and have a 31,000 mAH capacity
By my calculations, It’d weigh in at 5.1KG and give you a 15 minute flight time.
Double that to 12S20P and you should get… Well. Double that. ish… While being much kinder on the battery.
Personally. The Vruzend and to a much lesser extent, NESE systems, haven’t got tremendously positive user reviews for high current applications like this kind of thing. Read a discussion on the NESE from where it all started - N.E.S.E. the no solder module - Endless Sphere
To go the 18650 route, you’d need a high current BMS to keep things under control and a specialised power supply to charge it with. Mind you. The 18650 chemistry is a lot ‘safer’. Also a lot more time consuming to build - Hence a lot of the cost of ‘off-the-shelf’ e-PPG systems currently on the market. But once built, a lot more ‘user-friendly’ for the consumer.
I say go-for-it if you’ve got the skill / resources - Check out a well DIY documented battery build here:
https://leeashby.com/how-to-build-your-ebike-battery-lithium-ion-18650-cells/
Please let us all know how you get on.
*Disclaimer - contains personal opinion through experience and I’ve been drinking before posting ![]()
Beautiful setup - was the cost an arm and a leg or just one lime ![]()
I am still debating with myself and 2 other personalities in my head if I should go the one motor, two, or four motor route. The quality and dependability of a electric over ICE is such that I am now thinking one motor would be good - follow the KISS rule – sorry off topic
Batteries - since I am thinking i would like a trike now - I am looking at bigger packs.
Found these 90AH
90AH
The rep gave me a price of 1440.00US including ship/Duties to Toronto Canada
130WH/kg - so 2.9kW??- not as great as others and at ~50lbs it is considerable weight
This type of cell - retanglelish - gives optimized use of space.
Maybe someone could run the #'s - I suck at that.
Cheers, Patrick
Can you put that on a scale for us? I wish they sold just the battery alone. Did they send any documentation with it?
You gave us a link to a single cell, you would need 12 of those to power OpenPPG at the correct voltage.
yes - that is correct.
So the quote you received was for 12 of those?
Yes – 1440 for 12 - including ship/duties USD
@E-pusher I added it to the bottom of the sheet. I could be missing something (make sure the “User Generated Values” are correct), but it looks a lot heavier than our premade packs, and doesn’t provide more flight time than if you were to just add more lipos.
Good to know - thx for the input
I must say, I like the idea to make a battery pack out of 18650 cells more and more
@OpenSky this overview is a nice find: DIY 18650-cell battery-pack building KITS, five options for 2018 | ELECTRICBIKE.COM
@Lukas thanks for the 18650 cells source in Europe: https://eu.nkon.nl/rechargeable/18650-size/sony-us18650vtc6.html
@DanielArnett the Battery Pack from Paracell, as @CrypTunico posted, may be for sale as a single unit by itself. I contacted Javier (the person behind Paracell) in a post on the Paramotor Group at Facebook, suggesting that he should be selling them by itself, and he replied that I should contact him for a price (which I did not yet).
@CrypTunico did you take those photos yourself? why did you take the battery pack apart?
I would also like to hear how much this weighs, and whether it’s the correct voltage for OpenPPG (44-48 V)
I also think, that the BMS is very important - can you tell us the model/type and manufacturer of the BMS, if you have access to it?
Etienne, the battery photos I took from Javier (Paracell) Facebook page, during the assembly process. About the BMS I’m sorry, I don’t know. I’m a complete noob about electical systems.
All I can contribute to this discussion is a few more photos from Javier’s Facebook
RTF Paracell V12 Series PVP.pdf (565.5 KB)
Here’s a quote I got from Javier in January, he lists the batteries as discrete line items.
