You only average 3.8 kilowatts and your friend with the “newest E-Glider” averages 2.16 kilowatts…
You and your friend are ahead of every available Eppg’s, you guys are even better than Thomas Brandstetter> Single MAD motor - #22 by bratwurst
If you are not in a paragliding pod harness and over 80 kg Pilot weight, then Eppg’s are between 4.2 and 4.8 kilowatts (That could be the numbers for the OpenPPG SP140 even I was reading theoretical numbers like 3.5 kw average and the OpenPPG x4 uses 6.2 kilowatts.
