BMS hard cuts - suggestion
good explanations!
I would like to show you an esc in the picture that I have been using since 2012. You have the option (in my case up to 15 S since we are not allowed to have higher voltages in most of Europe) to connect to the ESC. (K4 / K5) you can then set the software as an example as soon as a cell group under e.g. 3 volts that the performance is throttled or just a maintenance goes out. the designers of the esc have been making many features for decades. however, these are often not known to diy or small startup companies.
Thomas
picture from MGM Manual HBC Series
