Using V1.2 power pack with the new v2.5 frame?
I have SP140 v1.2, unfortunately it got damaged by another pilot, broke the frame pegs for the cage. Does anyone know if the power pack dimensions are the same for the new v2.5 frame? Can I unbolt my power pack and bolt it to the new frame? From what I could find on the order page they seem to be the same dimensions.
The older V1 power packs can definitely be used with the V2 frames. It is the same bolt pattern so you can simply just bolt the old motor to the new frame.
