I love the idea of alternative or human energy powered flight, and have been thinking about this a great deal over recent years.
The big problem I’ve seen with solar is that the increased weight results in decreased lift, or with a larger wing, more drag. It seems that, with our current solar technology, it would be difficult to increase flight time, rather than decrease it.
Because you don’t want to increase the weight of your wing (otherwise I’d use the spray-on solar on the wing), the only place to really mount the solar is about your harness and such. I have thought that a real light weight (tent/parachute fabric with a carbon fiber frame maybe) air foil frame which encompasses you may reduce drag enough to offset it’s weight, and provide a reasonable surface for mounting some panels.
To me, the option to just have a solar cell with me so I could land, recharge, then take off again a few hours later still has merit, even if it doesn’t help flight time… Make EPPG camping an epic adventure
I wonder what the drag of a stationary blade is vs a slow-spinning blade as well… it could be possible to recharge the batteries with the propellers when thermaling, descending, or gliding… but again, if the wind against the blades doesn’t create enough torque to use the current motors as generators, it may take more weight than it’s worth to put that into action.
I think wing weight is far less significant with hang gliders, so I think solar coating a hang gliding wing could very well be worth it, particularly if the solar is built into the wing, so takes up some of the structural weight.
