I can’t understand how legs support work. It’s just a reclined plate (with a small angle) that should support legs (in flight?).
Can someone explain how it works and if you feel notiable difference from SP140 vertical support?
Post a picture of what you are talking about and Perhaps I could answer your question
Here’s an example image:
Red drawing is paramotor frame seen by side. A profile. Where black line is straight vertical is propeller reference.
As you can see X4 have this low side that goes just a little bit under seat. I don’t think it will change a lot in flight since motor is still vertical straight. Maybe this shape helps when running?
There’s a comparison with Scout that have reclined all the back with the motor vertical straight. In this case there will be difference in flying position. How much respect to vertical straight? I don’t know.
