Hello all,
I am an aspiring paramotor pilot, and after seeing the price of $7000+ for a typical gas unit, Justine Haupt’s blimp drive caught my eye - BlimpDrive Electric Paramotor I have already started building a blimp drive setup, so this first post is something of a catching up one. I am documenting this on a newly minted youtube channel: (https://www.youtube.com/channel/UCtMiqZYw7ZN9X2fNQxNuz2A)!
This design stands out to me as ideal for electric paramotors, sticking the props out in clean air and taking advantage of the smaller motor footprint. It’s also significantly lighter, the pole with motors and ESC’s will weigh in around 10-12 lbs, freeing up a lot of weight for batteries. Flight times will be nothing to write home about of course, but it’s interesting to see how light and affordable this setup will be.
I am building mine with an expectation of powered flight, not just a launch/boost for gliding. To that end, I needed more battery capacity. I also had costs on my mind, so I aimed to save money wherever possible. To achieve more air time and less financial commitment, I decided to build my own battery. Using Molicel P42A in a 12s6p fashion, I built a 25 Ah, 50 volt, 1.1KWh Lithium ion battery, weighing in at 10.5 Kg. Slightly heavier that Justine’s original, but with more capacity and the lower cell discharge voltages of Li-Ion, I expect 20 minutes. I plan on flying with more than one pack in the future for longer flight times, but this should get me in the air. Battery cost was about $400 USD. I had to buy a spot welder for it, but that’s something I will use for a long time. I have just now charged this 12s for the first time, internal resistance is below 2 ohms per cell, and it has taken every drop of the 25 Ah expected. I am excited to try it out.
As for the overall design, 2 major flaws stood out to me: Lack of pilot protection, and riser twist upon motor failure. The first will be solved with CNC machined carbon fiber frames that I will stretch a fine net or wire mesh over to guard the pilot from propeller shards and FOD. I am also attaching a 1/2" diameter, 24" long carbon rod to protect the prop from ground strikes. For the second point, I plan on mounting an arduino with a 6 dof gyro/accelerometer to measure rotation of the pole and shut both motors down if the rotation exceeds a threshold. This will need to be tested. I also opted for a pole that would not require reinforcing, a 1/8 inch wall thickness should give me a safety factor of more than 3 considering one side of the tube might need to support my weight.
That’s where I’m at so far.
A lot of my decision to pursue this was cost related, so here’s a run down of everything I’ve paid. No sales, no specials.
as of 1/16/21:
Actual costs after Shipping & Tax, USD: $4,109.69
Harness & Carabiners (glidersports): $347.39
Motors, props, ESCs: $1457.68 (t-motor seems to be unreliable, no updates in shipping after 3 weeks. I am leaving this cost here because buying from a retailer should be close to the same price. 130 kv U13II motors, 200A ESCs, 32x11 props)
Battery cells and supplies (18650 battery store): $444.02
Charger/PSU (buddy RC): $341.14
Spot welder (Keenlab): $255.59
Electronics (adafruit): $121.01
Electronics (amazon): $37.15
Electronics (ebay): $11.56
Hardware (McMaster Carr): $175.20
Carbon Fiber Tube (Forte Carbon): $544.00 (1.75" ID, 0.120" wall, 96" long)
QS10 electrical connectors (maxamps): $50.52
Carbon Fiber Parts (cnc madness): $253.00
M4/M5 hardware (Amazon): $35.97
More info to follow as I progress. I am open to constructive criticism.
About me: 26 yo, USA based paramotor pilot in training, I’ve been kiting for a year. My first flight will NOT be on this blimp drive, but on a moster 185 powered unit. I work at a hobby store, battery and motor/controller wiring are second nature to me. Both of my parents are hot air balloon pilots and I’ve been surrounded my aviation my whole life.
